Anyone seen this bodge before?
I have no aircon, front/rear wipers or clock at the mo (http://www.300zx.co.uk/forums/showthread.php?t=70067&highlight=electrics+problem
), dave saw my post & told me he had the same problem when he removed this wire form the footwell fuse box (see pic) - all worked ok when he put it back in!
Is this some sort of bypass/fix, I am wondering whether i should try it...
Though looking at the jap fuse box spec http://www.300zx.co.uk/tech/fuse-translation.jpg
I am not sure why this would work and effect air con & wipres!
Any thoughts??
Barry
Apart from the fuses for both are side by side!-the feed at the rear may feed both fuses,if that makes sense! LOL!
I had the clock fixed - that was working fine...
It is strange that they have all gone together - must be a power feed??
The garage claimed it was the switch plate on the dash pod but surely this would not effect the clock?
Thought i might take the switch plate off the pod & have a look behind - but not hopeful... Maybe the garage just nudged a faulty connection whilst trying to find the fault??
