Found this ECU chip in my car
I assume it's a Japanese one labled as 'Central120 Racing team'.
Made it a nice easy job to replace it with my new DTA one :)
Also noted that a Yellow/Green wire was deliberately disconnected, anyone know what this wire is for or can point me to the wiring diagram so I can trace it.
Gaz
A few imports come over with the Central 20. Its map will depend on exact version, from mild to aggressive and will be mapped for 100+ ron fuel which can be a risk in the UK.
There's a green/yellow wire that's the speed sensor. It may be that one.
That's a thought but this is disconnected and the speedo works (and was in kph until I changed the R10 resistor).
I have just had an alarm fitted and the guy doing it said the wiring behind the dash was a mess as it looked like someone had tried to fit or removed a turbo timer, so i wondered if it was anything to do with that.
Gaz
Which ECU pin is the wire connected to?
It's to dark out to see now, will have to look in the morning.
Will also look for a wiring diagram to get an idea as well.
Gaz
