Ive just had the zed 4 wheel aligned and the steering wheel is now central upto about 40mph. As speed increases above this i have to feed in slight right turn to keep the car going straight. I watched the guy track the car and everything was set as it should be.
The car has got new hicas arms but doesnt have the hicas working (as its got an aftermarket wheel fitted). Wondered if the hicas might be to blaim, or if its anything else.
Its not disasterous, just annoying really
most cars drift slightly to the left due to road camber, cars with wider wheels more so. wouldnt worry about it.
you can help combat it by setting up the car with more neg camber on the n/s/f & less on the o/s/f, but not so ideal for handleing.
