- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
I have a problem with the speedo in my '92 UK spec 300ZX auto, it suddenly dropped to zero shortly into my journey, flicked back up to show the correct speed a couple of times before dropping down to zero & staying there permanent. Without the speedo the power steering cuts out after a short time & the HICAS lamp comes on.
I have replaced the speed sensor on the auto gear box to no avail & tried a new speedo unit to no avial. Last weekend I jacked the rear of the car up & measured the ac voltage out of the sensor whilst in gear, ranged from about 1v rms to 3v rms depending on speed. Checked I was getting the same out of the 2 pins on the connector that goes in the back of the speedo unit. This was with the speedo disconnected.
Once plugged in this drops to a few tens of mV at idle to approx 200mV rms at speed. I measured across the rev counter & got a similar range so the speedo meter is loading the sensor OK I would assume?
I have been through the wiring diagram & the speed sensor appears to feed straight to the speedo, where one side of the sensor is grounded. The same connector sends speed information to the differential oil temp sensor & ECU, could it be a problem with one of these dragging something down on the speedo circuit?
Anyone have a circuit diagram of the speedo?
