is this rad any good????
Don't understand why he says it doesn't fit UK models, unless he means auto only, as they use both end tanks for cooling, Jap is only one.
It's also described as suggesting it may have plastic end tanks, they are half the reason for failure son the OEM rads.
Didn't notice mention of n/a rad.
yes i saw the bit about plastic end tanks.i emailed him about this one and he has some n/a ones aswell.
so are the oem ones plastic end tanks aswell if so that is where mine is leaking.
what would you put on it???
Yes, OEM are plastic tanks. There is no fix apart from replace. Mike Feeney used to be able to get replacement plastic end tanks which could then be bonded on to the old core - don't think these are still available though.
