June 4, 200620 yr started to clean all connections...and the injector connections (2 prong) are covered in the green corrosive stuff..is it me or do you have to take all the vacuum pipes etc to get at the connector on the passenger side nearest top? any other way of doing it? thanks
June 4, 200620 yr Yep! That's about the size of it, pain in the ar5e! Better still don't waste your time cleaning the green gundge off, just invest in some nice new ones, well worth it. also while you're at it some new coil pack connectors, as these become brittle. I just changed the plastic part of the coil pack ones, as all the metal inserts were clean and fine. I can give you a contact for the coil pack plastics if you want (gota look it up) otherwise Mike Feeney should be able to sort you for the proper ones (MJP)
June 4, 200620 yr can you give me the guys phone no. plus how much did you pay for yours? ie coil pack connectors etc
thanks
