My Project 300zx Update
Well after problems and much head scratching and umming and arring and lots of "dont worry love its only £50 honest"
Looks like i pressured my bottom end which forced oil out so i had a choice to make, do i give up or sod it its only money lets just go for it!!
So ive gone for it ;) just paid my deposit for my new engine and should be built in approx 3-4 weeks then a couple of weeks to ship over here :)
New engine spec is:
90mm Forged Pistons with full ceramic coatings
Forged Rods
ARP Rod Studs
ARP Main Studs
Block oil passages cleaned
Block redecked
Block water passage bored out for more water to back cylinders
Block Bored and Honed
Crank balanced and welded on center weight
New Rod and Main bearings (Ceramic Coated)
ARP Head Studs
Tomei 280 Degree Cams
Tomei HD Valve Springs
Tomei Solid Lifters
Titanium Retainers
Ferrera 1mm Oversized Valves
1mm Oversize Valve seats
Heads Pressure Tested
Heads oil passages cleaned
Heads redecked
Ported exhaust and intake runners
5 angle valve job
Combustion Camber work
Valve heights set
Metal Head Gaskets
OEM Valve stem seals
OEM Cam Seals
OEM Oil Pump
OEM Oil Pump Gasket
Also getting a steel 1 peice drive shaft shipped with it as well :dance:
Before anyone asks yes its expensive :smash: but tbh with the exchange rate it wasnt worth getting another engine in, ordering all the bits and building it myself.
So watch this space
Mike
  • Replies 28
  • Views 1.4k
That spec sounds amazing Mike :bow: Great news that you're straight back up again after your setback with the last engine :cool:
£7k is a bargain!!!
£7k is a bargain!!!
Also getting an RPS carbon/carbon clutch as well :rolleyes: :p thats another £1500 :smash:
:shock: :shock: :shock: thats a good price!
