Pure *!$@!*g Sex
The new Ducati Desmosedici RR motogp race rep, it makes over 200BHP and is fully road leagal but costs an eye watering £37,500 :shock:
Some more overtime is in order methinks.
YES! they get better looking with every new model and this is probably the best yet? My other thoughts tho are.... is it a reliable bike yet and do you still have to suffer the discomfort that seems to come with Italian bikes? I really am and always will be a UJM man. The japs seem to be able to combine style and comfort with performance without loosing any of them features.
But all that said. I wouldn't kick one off my driveway. ;)
And an affordable price tag!
Last time i rode a Duke I got a very numb bum and sprained wrists, and jaw ache from smiling :) looks good.
Shit me thats gorgeous!!! I want one :D
HAHA, last time i rode a duke i went 20ft up in the air thanks to a mong'deo driver!! :D :rofl:
Wow 37k for a bike! bet its awesome but I thought the whole thing was you could get to 60mph in 2.5secs for well under 10k?!
Very nice but spec, but what have they done with the zorsts??
Engine
Type L-4 cylinder, liquid-cooled, DOHC, Desmodromic, 4 valves per cylinder, gear driven camshafts
Displacement 989 cc
Power More than 200 HP @ 13,500 rpm (with racing exhaust (102 dB) - without catalytic converter)
Torque n/a
Fuel injection Four 50 mm Magneti Marelli throttle bodies, 12-hole "microjet" with injectors over throttle, manual idle control
Exhaust '4 into 2 into 1'vertical exit exhaust/silencer
Emissions Euro 3
Transmission
Gearbox 6-speed; Cassette type
Clucth Dry multi-plate slipper clutch, hydraulically actuated
Vehicle
Body Full carbon fiber bodywork
Frame Tubular steel trellis hybrid, carbon fibre seat support, aluminium swingarm
Front Suspension Öhlins 'FG353' PFF forks USD 43 mm pressurized, with preload, rebound and compression adjustment, TiN coated sliders
Front Wheel Marchesini forged and machined magnesium alloy wheels, with 7 spoke design as GP6
Rear Suspension Öhlins rear shock, with rebound, low/high speed compression adjustment, and hydraulic preload adjustment
Rear Wheel Marchesini forged and machined magnesium alloy wheels, with 7 spoke design as GP6
Tyres Bridgestone
Front Brake Two Brembo radial "monoblock" calipers with four 34 mm pistons; two semi-floating 320 mm x 6 mm discs, with machined flange: the same as GP6 wet race set-up
Rear Brake 240 mm fixed disc, floating caliper with two 34 mm pistons
Fuel tank aluminium alloy
Dry Weight n/a
Instruments New lightweight Corse electronic multifunction dashboard with LCD 'bar' graph tachometer, trip/odometer, anti-theft immobilizer, lap time measurement, oil pressure, fuel reserve, EOBD, clock, air temperature, rev counter
Version
Colors Two versions - 1) Desmosedici RR: Rosso GP with a white number plate on the tail section; 2) Desmosedici RR "Team Version": Rosso GP with broad white fairing stripe. A team sponsor decal kit will be provided with each bike.
Versions Single-seat
:bow: :bow: :bow: :bow: :bow: :bow: :bow:
