0-60 Trial
Out early this morning on the private track, managed a 5.65, 5.75, 4.93 and then in an attempt to beet the 4.93 i had a bit of a burnout and got 7.07. All in all i'm well chuffed, I had hoped to achieve roughly what i got on the first run.
Question, in data display mode i am not getting any readout for duty cycle, could some kind hearted person explain what duty cycle is and why i seem to be getting a zero reading at a stand still and when driving slowly? does it only register at higher speeds?
My car is a JDM TT 2+2 Auto with Megan decat, Blue Flame cat back, Mines ECU and Apexi induction.
Thanks in advance
DGM
Duty cycle is roughly defined as the ratio of the amount of time a signal is "active" to the amount of time available for the signal to be active. A couple examples. In the examples that follow, the amount of time available for the signal is 20ms (milliseconds).
Signal is never active = 0ms/20ms= 0% duty cycle
Signal is always active = 20ms/20ms = 100% duty cycle
Signal is active for 8ms = 8ms/20ms = 40% duty cycle
Thanks for the reply, is the duty cycle monitoring one function? if so what is it?
Thanks again
DGM
ok lets say our injectors can open for a maximum of 20ms then the duty cycle is effectively measuring the amount of time that the injectors are open ( all of the injectors ) It is monitoring the injector pulse, you never ever want to run 100% duty cycle...you need dead time which is when the injector isnt energized
