ZX wont start
Ok guys i was having problems with the battery this past few days so i left it on charge last night got it totally charged and put it back in the car today started the car first tick and drove about for a while then the car started cutting out on me and wouldnt even tick over until i turned the key off for a few mins then it started again, then when i parked it it cut out on me before i turned the ignition off and hasnt started since it just keeps turning over but wont start need help plz.....
Hi,
jayw, see my post on LOSS OF POWER just below. Could be similar problem??
Cheers m8 first thing i checked was the timing belt and its ill try out a few of those sensors in the morning and hopefully with a little luck thats all it will be....
Cheers again
Hello m8 in reply to earlier i had the AA out looking at the motor there and it seems to be the temp sensor is malfunctioning causing the car to think it is cold and therefore causing the car to flood itself by over dosing on the fuel there is a constant smell of petrol so i would advice you to look out for the smell of fuel on your m8s car and if you smell fuel it is prob the temp sensor.
If you's are near Crumlin N.I Call into the Autoplex and i will stick it on the computer and give all the sesnors a check over, Sudesh can get in touch through my email addy.
Send me you mail address again I thought I had you logged in my address book but it aint there!
