crystal or clear uk sidelights
does anyone know if these are available?
Mick,
If you are refering to the blank units located at the corner of each bumper then you can just replace them with the crystal clear ones.
If you are refering to the indicator/running light units located in the little square units next to the number plate then the answer is no.
If you are refering to the latter I can make a suggestion what a couple of my customers have done in the past to UK spec cars. What they did was purchase J-spec fog lights and crystal corner indicator units. With a bit of clever rewiring they popped the indicator bulbs into the crystal corner indicators and kept the running lights in the new J-spec "fog" lights. You could even put the running lights in the crystal corner indicator in the space behind the actual indicator bulb and use the fog light as an actual fog light (you'd have to place a switch in the car though).
Either way, there are possibilities to do what I think it is you want to do and I can help source the parts for you.
Dan
it's the front indicators and sidelights I was referring to not the corner units.
thanks for the info Danny.
Be careful. Be very careful.
Thats just how I started and look at my spec in rides now.
don't worry mate, my pockets aren't as deep as yours at the moment! lol
