As above, any ideas? Wheres the fuse for this, is it in the boot? Thanks in advance GLENN
Glenn,
You have a few fuses to check.....
All are in the fuse block by the drivers right foot >> http://www.300zx.co.uk/forums/showthread.php?t=66739
The main antenna fuse is the 10 amp one at the bottom left. (IN LAMP AUTO DOOR LOCK)
Also check the 10 amp one, top right (Audio 1)
Finally check the 10 amp bottom right fuse (ASCD A/T CONT/L)
As two of these are for the power antenna timer circuit, and one (first one) is the antenna fuse.
Thank you Dave, I'll go an check it this afternoon, cheers mate GLENN ;)
its in the fuse box next to the go pedal mate
If your aerial is faulty and needs to be replaced, don't be tempted to buy one from the US company on Ebay that sells what looks like new replacements. I bought one and could not get it to work. I messed about with it and the wiring for a couple of weekends before buying a secondhand one off Ebay which worked instantly.
