Just Purchased These!
Just purchased these, what do you lot think. Also anyone around the Crawley area to help me fit them, I will pay for your petrol to get to me and back home (as long as you dont live to far away lol)....
NISSAN 300ZX
TWIN TURBO BOV KIT
This is the cheapest setup you'll get anywhere that is bolt on.
We try to make life easy for you by taking away the leg work. We do our homework and put the kit together so that all you have to do is bolt the thing on.
Regards,
Matt
Description is:
2 x Supersonic TWIN TRUMPET Atmosphere Venting Adjustable BOV's
300ZX Adaptor Kit c/w with block off caps, cable ties, etc etc. Everything you need for a hassle free bolt up. No need for special tools or fabrication to install.
The Blow Off Valve has:
Adjustable boost release setting. Rubber grip.
2 Large Trumpets, very loud!
Hose/Adaptor Inlet dia 33mm.
Pressure tested, good for over (25+psi).
Neatly packaged.
EXCEPTIONAL QUALITY You'll be impressed.
Description is:
Neatly packaged.
Good luck fitting those to your outer pipes! From the pic the BOVs look rather large which could be a problem on the passenger side as it will probably hit the fuse box cover. Also, how do they propose you "plumb" these in? If you've got hard pipes fitted you'll need to drill a hole in the pipe, weld on a nipple and get a 33mm silicone sleeve to fix the Bov to the nipple. Not sure how you'd go about it if you've got the standard rubber hoses ...
I'm not trying to be (too) negative and I hope you're happy with your purchase. It's just that I know what a pain it is to fit BOVs to a 300 and wouldn't want someone to have high expectations of it being an easy job.
Good luck though.
Dan
Cheap and 300ZX don't mix mate, I'd save up for the Apexi BOVs as you get what you pay for with these cars.
Are these TURBO-XS ones.? Fitted mine to outside pipes and like previously mentioned ,they are abit tight around the fuse box,but I managed it.
If i was you , i would have a look at other people`s cars and see how they have fitted them.Do a search on this site for threads and pictures.It will give you an idea.Japfest is this week-end get your self there and have a look.
Just a question ,Is your car a auto or manual? :hyper:
Matthew's car is a manual ;)
'93 UK TT Manual
Thats good, cause i would`nt bother putting them on a auto,as you don`t close the throttle when changing gear.Just a thought.
My Car is manual
So should I return these, dont want to waste time fitting them...
The BOV`s you have ,can be fitted but like anything you may have to move and fabricate parts to do so,lay them on there side etc.The ones that have been mentioned are easyer to fit because of there size and the lack of space under the bonnet.
So like i said before , have a look around first at other cars , threads etc before you rush into fitting them.
Good luck :hyper:
looks they they go in the place of the stock recircs mate and look like they should fit but best to ask em to confirm where they should bolt to exactly as u may be missing a pipe that goes into the stock recirc pipe .
They state "Everything you need for a hassle free bolt up. No need for special tools or fabrication to install"
i thought an people have got bovs etc..on auto and the woooooooosh ok once you relese the pedal....
As Karl said above, they may be designed to go in place of the recircs like the Apexi ones. Try to check with the seller and if you need a hand I may be able to help!
CheerZ
Steve :)
'93 UK TT Manual
Thanks Steve, nice one buddy.
