Passenger window fuse
Hi guys. Does anyone know where the fuse is for the passenger side electric window? Cheers, Rob.
Rob, there isnt a saparate fuse for the passenger side window regulator. All the power is run off the drivers side main circuit, and controlled through the drivers side switch unit, with a mirroring switch on the passenger side.
Page BF-12 is the power supply circuit diagram for the power windows, in the Body section of the workshop manual (sorry I can't give you a link to it, as I don't know where it is anymore (it used to be, and could still be, on this site somewhere))
EDIT** And with the help of the guys below...... The actual page >> http://300zx.co.uk/cgi-bin/manual.cgi?list=bf&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=12&design=default&total=46
this one mate?? ;)
Cheers for that guys. The passenger side window had a couple of catches missing so had been disconnected by the previous owner. Took the best part of the afternoon to get the window out fit new catches, and reassemble. Then I thought a fuse had gone but realised I had the 'lock' button set :headvswal. Anyway, now I have two working windows :hyper:
