Owned her a day and here's the first problem. The left wing mirror seems to get stuck when I try to fold them in. Anyone else had this problem?
i stripped mine down cleaned em up and put em back together with a little fine grease on the parts and they glide in and out, mind you they were stinking in there.you can see the crap in there when you fold them in
I cant be sure but it seems that they are standing at slightly different angles when the mirror block and the holder are aligned.
Could be a crack on the belel, as they arent very strong, hope not cos if it is the whole mirror is fooked!
whats the belel? I can move the mirror backwards and forwards and both sides are stuck well to the car, just that the angles are slightly different. Also on the 'sticking' side I can lift up the mirror housing slightly - maybe not screwed on properly? I'll have a proper look anyways when the weather's better.
ops, bezel i meant!
Sounds like just the screws underneath may need tightening on yours though.
MY LEFT MIRROR DID THE SAME THING AFTER BUYING MY ZED and then after about two weeks just started working properly and has done ever since. :hyper:
hmm weird. It doesn't bother me too much but its just something that doesnt work and we all know we can't have thungs that dont work even though we dont necessarilly need them. Although I drove off today with the right mirror folded in and it was cool to be able to press a button to pop it out.
