FAO any window/door fitters
Hi,
My Mum's back french doors have a problem with the hinges as in they are coming away from the wall/frame. Can any of you guys give me any advice on how to fix this which I guess means removing the door.
Vijay
yes vijay open the door up ,,they are what we call flag hinges,,all you have to do is lift the door off the hinges its a bit heavy but not to bad then the screws will be visiable to tighten up or if they are spinning replace with a bigger diameter screw,,,
easy really bud good luck,,,jason
