Stereo fitting
Not that I'm aware of, unless someone has done what had been done to mine, and that is to have a pair wired in. You could always buy a converter from Halfruads, probably about ยฃ10ish
would that convert from the nissan plugs to ISO then?
great i'll end up with more plugs behind the dash than the electrics isle in B&Q... :confused:
no it doesn`t, one of a micra will fit and if it`s a jap one you may need an aerial adaptor aswell
Bob
Where do you get the airial adapter from?
Halfruads do them as well.
Yep!!
Not as many as mine, I've got a bluetooth hands free kit wired into my stereo wiring!!
i have an ipod control box for my head unit and i also use an Audiobahn equaliser in my sound system which has quite a few connections. is there plenty of room behind the head unit in the dash?
:rofl: :rofl: :rofl: In that case, probably not a lot of room then :D But then the converter lead isn't very long, only about 5 inches at most, so you should be OK.
