conzults
Thanks for the reference David - much appreciated!
The ConZult is a PC based diagnostic kit which can be used to (a) run full engine/transmission/AC/HICAS diagnostics (including fault codes and selflearn parameters, (b) provide real-time feedback of all sensors, © provide workshop tools (ie resetting ECU, setting base idle and TPS, disconnecting fuel pump, etc), (d) provides data logging, playback and analysis and (e) EPROM analysis/backup. It's the most advanced, yet user-friendly diagnostic package currently available. It is used by enthusiasts, Nissan performance specialists and Nissan franchise dealers alike.
Please let me know if you require any further information.
Dan
Also is there a Mac version or just pc? Thanks
The cable, as supplied with our ConZult, does not work on its own nor does it work with a Blatz unit. It is proprietary to the DTA equipment. The ConZult does work on a MAC but you'll need to be running Windows emulation software. There are a handful of users on this forum who run our ConZult on a MAC so they will be in a better position to inform you of what's required (I'm not well versed in all things Mac).
Dan
so what cables do i need and where can i get them?
Thanks, Ed
If it's for a ConZult then all the cables, hardware, software and manual are part of the kit - nothing is available separately.
Dan
