Clutch adjustment
Hi all,
After fitting new clutch and flywheel last week the biting point has completely moved. I did adjust it on the clutch pedal but it has since moved back - right up the top. My question is can you actually adjust the biting point or will it keep moving back to where it wants?
Thanks,
Paul.
I have the same problem every time I change a clutch no matter what car it is. You have to let it ware in a bit. I always refuse to drive on a new clutch, and make hubbie have the car for a week or two. Then I get you use his. (I go through clutches big time it's all those drop clutch getaways & holding it at the lights on the clutch)
