Headlight help
Yes it's them Jap lights again.
Ok, lost dip on the driver side. Fair enough.
Removed the bulb, had another bulb but with no earth strap, so soldered one on. replaced the bulb, turned on the lights. On came all the lights but not the one I replaced. When I say all the lights, I mean the left hand dip and both full beams at the same time, but only verry dim.
Could this be a faulty bulb?
When I remove the new bulb I get working lights on the left and nothing on the right.
Are both dip and full beam fed by the same feed? and do I have to have the dip bulb conected to get full beam?
Any one help ( if you can understand what I mean)
Chris..
Chris..
Hi Chris,
FYI: both dip and main are fed from the same wiring loom. A possible reason why the "new" dip beam bulb wasn't working could be that it didn't earth properly (I take it you earthed the additional lead to the chassis)? Other reason may have been that you plugged the fixed spade connector into the wrong slot on the grey connector ...
If you want to replace both dip beam bulbs with genuine H3C bulbs then I've got them in stock - just give us a shout and I'll get them out to you.
Regards,
Dan
Hi Chris,
Regards,
Dan
Thanks Dan,
I hope it is just an Earth fault. As for the offer of the bulbs, thanks again but I have two new ones on order.
Chris..
