Another Idle problem
Idle dropped of yesterday for no reason that i am aware of, it now sits at 500 to 650 ish. When started this morning there was no choke function, ie the revs went straight to 500, as the engine gets warmer the revs rise at idle to 650, no error codes, any help much appreciated as always,
David
have u checked the tps bud ?? Has it been moved or knocked recently ?? also is it hunting or stable ?
Tps hasn't moved, connectors are reasonably clean and i'm searching for the adjustment/setting step by step. The rpm is stable ish, but sometimes it cant hold itself there and cuts out.
Anymore thoughts appreciated.
