Hi. Just bought a copy of Nissan Datascan, and it shows a code 55 which is all good, but when I'm on the move the o2 sensor gauge tends to cycle up and down the gauge. Is this normal or is something not right?
Rob
That is correct. If they dont move, then you have a problem.
By default datascan only shows the Left hand sensor, you need to go into the settings and turn on the Right hand sensor too, so you can check both.
Cheers, I'll have a play about with it again later.
