Koyo radiator
Most probably. However its always a good idea to improve cooling and the Koyo is such a quality item.
:nana2: Spot on :nana2:
Been running close to 14psi for years and only had a standard rad. If the water temp is close to the thermostat working temp then you don't need a larger rad.
However, on hot days, especially the blast back from Le Mans last year the temp was around 95-97C.
mines 15psi still on standard rad,,no worries at all bud
Apart from the fact that your rad looks crap in the Beast & if you go over
50 MPH all the water in it evaproates........... :nelson:
:nana2:
