Been trying to get some for my connectors i.e. water temp sender, coilpacks, battery etc.
Been told by 2 local motorfactors to just use normal copperslip grease.
Is this any good for electrical contacts???
Or should I just wait and get some proper electrical contact grease.
Never heard of anyone using copaslip grease, I would wait and use dielectric grease unless someone can tell you otherwise.
whatever you do dont use copaslip on electrical conections its a grease and copper compound and copper as we know is a conductor of electricity it can short out connections giving you wrong sensor readings and if used in the wrong places could cause shorts bad enough to burn out connectors, wiring etc. even cause fires.
