Please Help
My zed is poorly, was on the mainland yesterday when develooped the mother of all mis-fires!! She sounds like a bloody V8 and the idling is VERY lumpy I have absolutely no knowledge at all of the zed engine, so i have no idea what would be causing it, please can one of you genius's throw some suggestions my way.
Scotty
did it stop after you let the car cool for a while as it could point to the ptu.
if not check all of your connectors to the coilpack and the injectors.
deffo sounds like its dropped a cylinder or 2
Ditto
mate. you need to do an engine diagnostic 1st
if you havent got the software, ask a local member or youl have to do it using the lights.
Ok
this happened to me once and it was just a loose coil connector
go out and look at your coil pack connectors and push them back on to see if loose
if that doesnt work out try disconnecting one at a time to see if it makes a difference if it doesnt you have found the offending cylinder if its a problem like that
look here for diagnostic info
http://www.aus300zx.com/tech/ecu_diagnotic/ECU%20Diagnostic%20Switch.htm
Right update, I have checked all the coil connectors, they seem to be okay, still running a bit rough, initial pick up on acceleration is very poor but once shes moving, it bloody flies!! I've done the ECU check code 55 is showing, Now I'm really confused.
this happened to me once - turned out id knocked one of the connectors loose from the ptu when i was working on the radiator. silver box at front driver side of engine bay near the cam end cover. make sure connections are tight both sides.
Sorted, loose connector on PTU, cheers fellas Scottys happy again now.
This may be rubbish but on the diagnostic disk I got off ebay for the following problem:
Engine sounds rough when idling it gave this explanation:
Engine misfiring in 1 or 2 cylinders, try replacing spark plugs or spark plug wires.
