Steering wheel.
Had some work done over the weekend, and when I got her back the steering wheel is out of alignment. Is it easy to take off and put right or is it a pain in the ar5e to do.
Did part of this work involvesuspension component changed without a proper suspension alignment ? If so, then you dont want to remove steering wheel, you want to get suspension alignment done.
I had a water leak and the engine core plug needed to be replaced so garage had to strip it down, dont exactly know what they stripped, thought it was a bit odd that the wheel wasnt straight. Do you think I should take it back.
Take it back - it sounds like they've had the steering rack out or similar and re-tracked it without first having the steering wheel straight. It won't do any harm as it is other than annoy you. Mind you, you can sometimes get tyres catching the inner wheel arches if it's way-out.
Good luck
Jack
