April 27, 200620 yr Had some work done over the weekend, and when I got her back the steering wheel is out of alignment. Is it easy to take off and put right or is it a pain in the ar5e to do.
April 27, 200620 yr Did part of this work involvesuspension component changed without a proper suspension alignment ? If so, then you dont want to remove steering wheel, you want to get suspension alignment done.
April 27, 200620 yr I had a water leak and the engine core plug needed to be replaced so garage had to strip it down, dont exactly know what they stripped, thought it was a bit odd that the wheel wasnt straight. Do you think I should take it back.
