hks evc 4 fitting
Going to plumb in boost controler soon an i cant find any fitting instructions on the web for twin turbo cars .Is there any links of were to tee into the turbos .Thanks taff.
I have heard that you should get an 'expert' to fit a boost controller and not do it yourself. I have a Greddy Profec II B that should be fitted by Zedworld this week.
ย
Anyone else fitted a boost controller themselves?
Thanks mate looked at that link only shows single turbo fitting.
Thanks for your help mate but the text is unreadable on the hks evc IV fitting instuctions on that link.
I presume you know the wiring loom connections??
ย
with regards to the "plumbing" not as hard as you think ;)
ย
take the smaller vacuum pipe and T into a vacuum source on the LHD of the balance bar
ย
then you have 2 other pipes to connect, another vacuum (one with the filter) which you need to run to the front and then T off and plumb into another vacuum source before the throttle (theres a source on the black pipe just before the throttle which you can T into)
ย
the last pipe again needs to T and run both pipes to the wastegates.
ย
remember to unplug the OEM solonoids ;)
ย
Mike
Here you go:
ย
-Andrew
