wont idle
hi guys,i fitted my greddy intercoolers yesterday and also found a boost leak and sorted that too,but since putting the car back together it wont idle,as soon as i come off the throttle it cuts out,it's very slow in making boost and i'm getting a pop from the exhaust whenever i blip the throttle.
any ideas? should i have done an ecu reset?
thanks in advance
Paul
Have you made sure all the hoses in and out of intercoolers are connected tightly,as that to me sounds like a massive leak somewhere?if it was fine before you fitted the intercoolers id check back through and make sure!
Did you leave any bolts out of the front of the coolers? They go into the end tanks and will cause a leak if not plugged.
in the words of the great homer simpson.....DOH!!!
since the new coolers never fitted onto the brackets i left the bolts off :wack:
Paul
i took the bumper off again today and put the bolts in the intercoolers.....all is fine now,thanks again guys :bow:
Paul
