i used wd40 and a toothbrush to get rid of that green like stains in the connectors, in the ptu, and temp sensor, and the grey round thing just opposite and below the left air intake... HELP HELP .... STUPID ZX....
Car Wont Start At All.. It Just Keeps Turning, And The Auctional Gong Soung Like A Horn As Well.. Any Ideas ... Will Be Appreciated
probaly a poor connection on the cas unit.the round thing as you put it.the cas rotates when the engine is cranked.as soon as it detects 1 degree of rotation it signals the ecu to latch the fuel felay.if you mark its position on the housing it sits in then remove it,with the ignition on rotate the drive spindle on the rear of it.you should hear the fuel pump start and hear the injectors clicking.hope this helps.
i did the same to my ptu right before i put my engine back and and killed the ptu. so i got another. will sell it for 40 if you need one
