Datascan results
Can somone cast an eye over these datascan results for me please and tell me if they look ok.
ok
thats got a few things different from mine on it
Your tps voltage seems to be out a teensy bit and your rpm is a bit high, mine sits at 750 and my tps is .44 ( tps should be between .4 and .5)
my temp also sits steady at 81degrees
yep, TPS should be .44v but tbh .4 is close enough i'd say.
Water temp a touch high/
Idle speed way too high.
Where can i get my mits on a copy of Datascan, is this Nissan software i have to pay for? I already have a Conzult box
Turn on O2 Sensor Right Hand too. Check both o2 sensors movement at 2k+
Your Voltage is on the low side. Recent flat battery ? or charging(alternator) problem
Temp on the high side, had you just been for a hard thrash? TPS a little low. Timing ok. RPM a bit high with AC off.
Thanks for all the reply guys.
Legreth the o2 sensor reading sits at just under 30 like in the pic and does not move at all apart from a slight twitch, I thought it was supposed to move quite a bit?
Not sure why the temperature is high, I did go for a 30 min drive then let her idle for 10 mins before I linked up datascan, what should temperature read?
Car has been sitting for 6 months, I did start it every 2 weeks, so probably why battery is a bit low.
Both o2 sensors should show a lot of movement at 2k+ rpm. Making sweeps backwards and forwards across the range. If not then they not working correctly, and will be screwing up your mixture settings.
