How have your read these codes? does your car have the extreamly rare OBD 2 port from 1996 ?
Having worked any many 1996 to 2000 model they still had the Conzult port, on these the later 16 bit ecu still used the ConZult port so you have a rare beast there.
The codes you logged are a little mysterious as there is no feed back from the egr flow and are more generic than specific, if you do have an OBD2 port you shpuld be able to look deaper into the issue with a proper scan too, still realing from it having one... good luck.
JeffTT ·
When I had my cam belt done, Jeff said I had a leaking tension rod bush.
So I thought fit poly bushes and why not do the TRA at the same time.
Not such a bad job but wow what a difference it makes on the bumpy roads, much smoother.
