Vinyl or Leather
I am going to attempt to retrim the inside panels of my 2+2. Any suggestions on where to buy the material. I am thinking of going for black and stitching some sort of pattern within it to make it a bit less dull and boring.
I would prefer vinyl but may use leather.
TIA,
Dave G
TIA,
Dave G
look in your yellow pages for textile shops/ distributors.
vynil is much easier to work with, ie. stretching around bends and such, and most outlets that do the vynil will do matching leather or vice versa.
I personally think Vinyl is easier for door panels unless you are a bit of a whizz with a needle and thread. Secondly it is so much cheaper and IMHO achieves the same result. Sourcing material is as already said, a case of searching your local Yellow Pages or internet.
Don't get vinyl that is too thin, I would recommend it is about 2mm thick, allows for stretching.
just done mine today in vinyl. cost me £8 per meter and 2 meters did the whole front of the car and the cowl over the clocks. Im gonna get 1 more meter to do the rear quater panels.
I did it in leather a while back but it is harder to work with, dosent stretch around the curves too well and dosent seem to stick down as well either.
whats the difference between leather & vinyl apart from the obvious, (eg) pros/cons does vinyl look as good leather ?? thanx
Thanks guys I will go do a local search now.
Dave G
