Water Leak!
Well after getting new engine and numerous auto boxes replaced she thought she would decide to blow a coolant line.
Got back from work ok, and checked to see if I had any leaks from autobox. No leaks from autobox, cool, but instead a load of coolant was coming from somewhere at the rear of the engine bay right in the middle, anyone got any ideas??
Cheers.
aye its almost certainly one of the turbo coolant hoses. or the little 6mm hose above the EGR valve, both are a fair task to change! youl end up with no skin on the back of your hands but it can be done.
theres also a bypass that can be fitted but i just repaired mine properly.
Fraser
