Water Leak!
Well after getting new engine and numerous auto boxes replaced she thought she would decide to blow a coolant line.
Got back from work ok, and checked to see if I had any leaks from autobox. No leaks from autobox, cool, but instead a load of coolant was coming from somewhere at the rear of the engine bay right in the middle, anyone got any ideas??
Cheers.
the 2 hoses from the engine to the heater.bulkhead always a prime area.
aye its almost certainly one of the turbo coolant hoses. or the little 6mm hose above the EGR valve, both are a fair task to change! youl end up with no skin on the back of your hands but it can be done.
theres also a bypass that can be fitted but i just repaired mine properly.
Fraser
