Power Steering Question
As the power steering has a return pipe, does this mean that it is self bleeding.
Ive cut into the hydraulic system to fit a Hicas Eliminator & then closed it up again, if I top up the power steering fluid will that be enough ????
I am Pretty sure they are self bleeding on the Z32's i am sure i will be corrected if i am wrong;)
Yes you should just be able to top it up!
Cheers Andy
