Strollin thru the latest jap Performance mag there is agut with a modified Zed with 'lagged cold air intakes'.
Does this rate alongside the PC power supply fan turbo upgrade or are there real bhp to be gained (?!)
If so im straight down to tesco for 50m of Alcan alu foil....
PS At least I'm posting about power issues not just bulbs now ....
Glenn
Lagged cold air intakes??
Sounds like a load of old b@ll@cKS to me but then again I haven't got a clue what there on!!
Pardon my french Craig!
Steve
i suppose in a very very slight way this could be a slight variation on a nitrous system as if im not mistaken thats all a nitrous is really doing but under a lot more pressure or am i taking this idea beyond the realms of possibilty hey maybe someone could invent a dry ice cooling system around the pipes lol
I find that either turning off the Air-conditioning or the heated rear window!...gives a nice performance boost!(at no extra cost)
JEZ300Z
Try this one for a perfomance mod.....
The Darwin Awards - It's an annual honour given to the person who did the gene pool the biggest service by killing themselves in the most extraordinarily stupid way. Last year's winner was the fellow who was killed by a Coke machine which toppled over on top of him as he was attempting to tip a free soda out of it.
And this year's nominee is:
The Arizona Highway Patrol came upon a pile of smouldering metal embedded into the side of a cliff rising above the road at the apex of a curve. The wreckage resembled the site of an airplane crash, but it was a car. The type of car was unidentifiable at the scene. The lab finally figured out what it was and what had happened.
It seems that a guy had somehow gotten hold of a JATO unit (Jet Assisted Take Off - actually a solid fuel rocket) that is used to give heavy military transport planes an extra "push" for taking off from short airfields. He had driven his Chevy Impala out into the desert and found a long, straight stretch of road. Then he attached the JATO unit to his car, jumped in, got up some speed and fired off the JATO!
The facts as best as could be determined are that the operator of the 1967 Impala hit the JATO ignition at a distance of approximately 3.0 miles from the crash site. This was established by the prominent scorched and melted asphalt at that location.
The JATO, if operating properly, would have reached maximum thrust within 5 seconds, causing the Chevy to reach speeds well in excess of 350 mph and continuing at full power for an additional 20-25 seconds.
The driver, soon to be pilot, most likely would have experienced G-forces usually reserved for dog-fighting F-14 jocks under full afterburners, basically causing him to become insignificant for the remainder of the event. However, the automobile remained on the straight highway for about 2.5 miles (15-20 seconds) before the driver applied and completely melted the brakes, blowing the tires and leaving thick rubber marks on the road surface, then becoming airborne for an additional 1.4 miles and impacting the cliff face at a height of 125 feet leaving a blackened crater 3 feet deep in the rock.
Most of the driver's remains were not recoverable; however, small fragments of bone, teeth and hair were extracted from the crater and fingernail and bone shards were removed from a piece of debris believed to be a portion of the steering wheel.
Epilogue:
It has been calculated that this moron nearly reached Mach I, attaining a ground-speed of approximately 420 mph.
I saw the article. Basically he is lagging his intake hoses into the throttle bodies with insulating foil, presumably to reduce the effect of the ambient under bonnet heat on the hoses and therefore the air charge. Used quite a bit in motorsport. I think the Demon tweeks motorsport brochure has some special foil - I'm not sure kitchen foil is going to cut it. BHP increase? marginal on a hot day. But could help under bonnet cosmetics.
