new compresion test results
ok i have done another compresion test.
on a engine that was given a clean bill of health, by one of our traders
recently.
the cold results are
......cadpauls results cold.....
dsr 130 psi..... psr 130 psi
dsc 130 psi..... psc 130 psi
dsf 135 psi..... psf 135 psi
......guvnors results cold......
dsr 130 psi ..... psr 120 psi
dsc 125 psi ..... psc 125 psi
dsf 130 psi ..... psf 125 psi
this car has been stood for 2 days.(mine was stood for 4 months).
any input would be very greatful.
(or have i some bad news for cadpaul :rofl: )
Unless your compression tester is sick then I'd guess you have two engines with problems.
i'm going to put pauls back together run it and see what i get.
as soon as i get time.
See if you can borrow another compression tester from somewhere.
got a second tester and the results are almost the same give or take a psi.
just running the engine now to warm it up then test it again.
If all cylinder readings are within 10 percent of each other, no further testing is required and compression is considered optimal.
good luck,
whats wrong with cadpauls engine for you to have it??
Membership No 0780
INSURANCE GOOFA
good luck,
its just too slow :tongue:
the test was done again when warm
and each cylinder was up by 15 psi
conclusion - both engines are fine
your panicing now LOL
even with your secret mods i'll get you :x: :nelson: :tongue:
Nissan Manual! - http://www.300zx-twinturbo.com/cgi-bin/manual.cgi
(Engine Mechanical)( page 9) (warm Engine!)
As Stated 186PSI is standard
As Stated 142PSI is Minimum!
Difference between cylinders 14PSI Max.
as I said before
as I said before
So youre quite happy that the result's are the cylinders Psi readings are less than 10% of each other but they are near Minimum recommended PSI values? :confused:
yes mate
i must be having a bad day (Z)master so i apologise
but you're getting right on my T!TS
yes mate
Oh Right And?
Guvnor wants to know if his engines ok! He has come on here for ADVICE so i am letting him know if his engine is ok!
After all i happen to be a Mechanic!!
Is Andyp getting on your T!Ts too?
not that i'm wanting to step in here guys, but could you BOTH be right...
with the extra 15psi when warm it shows that the motors are both within the manuals guidelines doesnt it...
after 10-15 yrs and 50k+ miles would the figures stated be classed as "within normal parameters"??
i'm no mechanic by a long shot, and may be talking out of my ar*e, but i'd say the figures stated, given the parameters, suggest the motors are indeed fine..
if i'm wrong then so be it, wouldnt be the first time.. lol..
T
T
Great though isn't it Mate you try and help people and they get arsey! :(
I would say that you should be looking at 165+ PSI (Warm)for a Good Sound Engine.
Incase anyone should be looking at buying a good used one!:)
T
What do you have Mate a TT or an N/a?
i have a TT i bought from a good lad on here, goes like a dream and i love it to bits..
different to the skyline but in a good way..
T
T
Good Choice i've always had TT's! Never owned a Skyline but driven a few in the Trade. :D
