well i was on rt 95 in NJ wen i floored it 1st 2nd then 3rd at about 4 or 5k mybe 90 or so mph the Z turned off. (gave a lil pop before it stopped not a loud pop( no smoke no fire no oil on the ground)... no brakes or anything! got it safly on the side of the highway and tryed to fire it up and it wont just cranks..... i was not hearing the fuel pump "wine".. so i assumed it was the pump just gone bad....got it towed home and changed the fuel pump (to a walbro 255 high pressure" the tried to fire it but no luck.... tryed to push start it and it "sounds like"it on but its not realy i dont know how to explain then turns off. so i pulled the spark plugs so i can see how they look and let the motor air out i might have flooded it while trying to crank it.. they looked fine a bit black but fine they have mybe 1k on them..... so tomoro i will put the plugs back and see it fires....
about a week ago it would not start also (after installing the boost controller) we tried firing it up for about 2 hours then we gave up let about 2-3 hours later i was like im going to see it it starts and it did wtf!
can it be the PTU i was reading some treads and it said cheack the PTU.... i will see tomoro.... how can i tell if the PTU is bad?
my question is what is wrong and could i have harmed the motor becuase i was going fast when this happened?
thanks guys
