Im trying to remove the rear steering rack (for want of a better term)
I cant get any movement on the knuckles that fit to the rear axle's short steering arms.
They appear to be unusual in that they have a bolt at the rear which holds in place an aluminium cover about the size of £2 coin.
Through the opposite side they appear more normal with the tracking end held on with a single bolt to the knuckle and steering arm.
I have undone everything and am hammering hard with the correct size joint splitter ( fork type ) but I cannot get the end of the steering arm to separate from the trackrod end.
I am trying to fit a Hicas eliminator which as you may know uses the steering rack arms screwed in to each end of the silver alley plate, so I need to get the tracking ends of of the steering arms.
Has anyone ever done this before...can you help with some advise.
Hi,
