In memory of Mandy
Wideband O2
I'm fitting my AEM soon and AEM also do a wideband gauge so my question is would there be any point in fitting this as it would only read from one side??
Mike
I'd get another sensor and plumb it in the other side and a switch wired to both, that way simply switching over gives you either reading on the gauge.
Bosch UEGO replacement sensors from AEM are around 45-50 quid, assuming your going to use the wideband UEGO controller which also switches between AFR and Lambda readout at a flick of a switch. ;)
Cool stuff........
cheers
smithy
