Hi,
Just wondering if these are exactly the same? I have just installed a USB 2 PCI card and the internal connector (pins) don't seem to work :(
Vijay
usb 2.0 is faster a lot faster i dont get what your saying is wrong
Just read my post, not too clear :( The problem is with the internal USB connector pins to connect to the front USB port don't seam to work :) There is also a 5th pin with "NC" which I assume means not connected? My front USB port has 4 connectors/
Vijay
no mate, I want to connect the front USB connector to the USB 2 PCI card.
Vijay
Externally the cables all work the same but internal connectors aren't to any particular standard.
You usually need to get an add-on panel and connectors for your particular motherboard although you can probably bodge one up yourself if you can work out which pins are which - there's only about 3 wires used anyway.
