SATA drive help
I've just installed a second SATA drive and i cant get the dam thing to work.
my MOBO is an ASUS A6V Delux, i installed some raid software and it shows up on that, but it doesn't show up on "my computer" i was to use these drive independent of each other.
if anyone can help 01920 411633
cheers chris
Have you got other drives on the standard IDE ports?
I had this problem on an Asus A6V board and apparently not all combinations of IDE/SATA work.
It's not just Asus boards either it seems to be a problem with many earlier SATA boards.
Not sure if there's a BIOS fix but I just removed one of the other drives and it started working.
sorted it now, had to right click on my comp and manage the drive, cheers
