HICAS : cannot remove one of the ball joint sockets
I managed to remove one side, obviously the one which has been already changed on my car ....
I don't manage to remove the other one, completely stuck.
I put a 17mm wrench on the other side on the "width accross flats" rod end but it starts to splip and to crush it !!
If I continue, my rod end will smash.
I put a ton of WD40, I torched it, it doesn't come loose.
Any help ?
I had the same problem.
Had two chaps using long bars and it didnt move a smidge :smash:
Ended up having to replace the stuck arm joint with a new one...
Although... the hicas eliminator was being fitted so i didn't need the rack anymore or the stuck arm.
Not alot of help if youre intending to keep the rack though..sorry
The problem is I don't manage to remove the arm joint I want to replace !
How did you finally remove yours ??
And as I torched it, now the ball joint is no more tight with the socket, huge play !
I'm obliged to replace it. I want to keep HICAS.
I think I'll try to grind a bit the rod end to be able to put a larger 17mm spanner...
I'm not confident.
remove the alluminium stroke stopper on the far end of the HICAS power cylinder that you were able to remove , so you can get more grip on the rod within the power cylinder and keep it from rotating (on the other side.)
http://300zx-twinturbo.com/cgi-bin/manual.cgi?list=st&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=51&design=default&total=98
usually that does the trick.
What I did !
I even filed more the rod end to get more grip. I crushed it.
Hopefully, I finally got it !
You know what ?
The previous f*cking owner punched the rod end on the ball joint socket I didn't manage to remove. Unbelievable ! That's even not necessary.
I was obliged to file these marks in the small space available.
Boths arms are now replaced and I performed a new alignment of the hicas (3mm stroke on each side).
