Venom 550cc Injectors
Are these good upgrade from stock. I have a set bought by the garage that damage my Nismo's.
I have called the company they order it from - apparently its a UK company and they claim its direct replacement but just need fuel re-map which I already got via Ztech.
Any one used them or running them in their car?
Ade
been a few bad reports in the US, not many running over here, if a garage has damaged your nismo ones i would insist on nismo replacements as there much better!!
blackmagic spent ages looking to these do a search, and read what he found out. these are much cheaper than nismo's so ask yourself why there aren't a lot more people using them. as Kirbz said nismo's were in it before and thats what you want back in it
http://www.300zx.co.uk/forums/showthread.php?t=50527&highlight=venom
found link for you read his No. 8 post
I have been through all that. It is a long story. Drag them to OFT last October for a job done back in August - engine rebuild and turbo upgrade and all that.
The garrage initially denied liability. Having gone to OFT, they OFT adviced them to source and fit the same injector or it equivalent - and that is my problem. The garrage is now claiming the Venom is an equivalent.
Not really sure of what to do now. my rebuild warranty will run out in July with the same garrage. If I fit it now and there is fuel shortage leading to engine failure outside the warranty period, it will be easy for the garrage to turn aroud and say, it wasn't due to bad injectors
hmmm its not equilavent its just alot cheaper!! i would still ask for the nismo ones to be safe
its not an equivilent! just because it has the same cc rating doesnt mean its comparable. Nismo are genuine Nissan Motorsport items - Venoms are pattern parts.
bit like someone trying to give you a 32" Goodmans telly when they damaged your 32" B&O TV!!!!!
insist on the Nismo's mate!
whats wrong with goodmans telly's??? :D
LOL! nothing mate - wanna swap one for yours!? :D :D :D
hmmmmm maybe not :D
That is precisely the issue. As far the garrage owner is concern, the two injectors are made for the same car, they are of the same cc then they be able to do the same job! Right?
Wrong, I once bought a Beko tv that lasted only 2 years, I then bought a sony and been using it for how long now? 5years.
Its difficult to get these people to see. It's not their car so why should they care if it blow a piston or two?
The Office of Fair Trading did make worse for me by the stupid clause of "or its equavalent".
I'm now running a car with big BB turbos but stock injector and cannot raise boost past 1bar. How pathetic is that! :mad: :( :headvswal
i would get all the bad report's about the venoms and take them to the garage and also get back in touch with the O.F.T. and try to explain this point to them. dont think they'll beable to find many good reports on the venoms
