The car is chipped and I want to adjust the boost to around 0.9 - 1 bar. Only running 0.62bar now. Where do I adjust the boost.
There is something at both sides of the engine that looks like it ment for adjustment of the boost. Tried turning it clock wise with my hand. No luck. Seems like it's turned down all the way... No problem turning it the other way though.
Not sure what your adusting, but they do not have anythiing for boost adjustment as standard.
You can either with Boost jets (mig weld tips) of around 1.0mm dimension in the boost pipes, or fit an electronic boost controller.
Is there no other way of adjusting the boost without jets or controller?
Yeah whatever happened to old usual old bleed valve setup for the average turbo'd car?
