oil cooler advice
need your help again guys.....
the car is getting fixed now but have been told that the front oil cooler is damaged and leaking as some twat at mot station(before i picked up said car from previous owner) had moved the car with both front tyres flat and has bottomed it out and damaged it!! my question is this,what cooler or coolers are fitted to the front of car behind and below front bumper and even better has somebody got any pictures so i can start hunting for a new one or go about getting this one fixed.
thanks in advance
this car might see the summer if they get a move on!!
simon
1990 uk twin turbo manual
this might help si, I know it goes on about changing the gearbox cooler, but the principle is the same. ;)
clickety click
from front bumper to engine
engine oil cooler
air con radiator/condensor
coolant radiator
engine oil cooler
coolant radiator
thanks for your reply greg,excuse my for being stoopid but i am not mechanically minded, i take it the cooler lowest to the ground is the oil cooler cos it is leaking engine oil and not water :)
simon
engine oil cooler
coolant radiator
thanks for your reply greg,excuse me for being stoopid but i am not mechanically minded, i take it the cooler lowest to the ground is the oil cooler cos it is leaking engine oil and not water :)
simon
simon
yes mate that will be your engine oil cooler
unless you have an aftermarket oil cooler for the gearbox,in that case the oil would be a redish colour so yes your engine oil cooler mate
how much for a stock replacement if required
simon
simon
hmm not sure give mike mjp in the traders section a shout he should be able to source you one ok
greg
greg
will do thanks
