aircon removal
Hi peeps!! kust wanted to check on a couple of things.... I'm in the process of changing my timing belt and install my koyo rad. Want to get rid of the aircon while i'm at it.....done the search on the site and help was very usefull.... Does the heating , demister etc run independently of the aircon, so when i ditch it , i will still have the demister etc......plus , is there a giude on tt.net or anything like that to follow, just to be on the safe side?
thanks
Mark
Heater is totally seperate mate, no probs there!
I also removed all the lines to the bulkhead whilst engine was out-might be tight with it in tho'! :)
would any one have a pic of the valve I use to let the aircon gas out please. ( to be collected :D ) Got a fair idea where it is, but just need a to be sure...
Mark
any ideas peeps?
thanks
mark
ps..any guides available to ditching the aircon?......
There should be 2 mate!-can't remember where tho'! :o -look on the pipework for a plastic screw-on cap, that'll be it! :D
plastic screw on cap is near the bulk head you can take the aircon pipes out up to the bulk head by taking the battery out;)
little update, got rid of the aircon today ( very easy to do )....turns out there was next to no gas left in the system...( havent used it in 2 years anyway) amazing how much room you have to work when its all gone. Gives my new koyo much more air to cool things!! Anyway got 2 questions now if you dont mind! What is the fan in front of the aircon rad, can i ditch it as i'm using the OEM viscious fan anyway and the 2 oil coolers at the front of the car are for what. I think they are for engine oil and the really small one power steering fluid? just need to know as they are very rusty and might need replacing!!
thanks
Mark
thanks
Mark
the electric fan is for the aircon do you have a tt auto if so one cooler is for the engine oil the other is for the auto box I think not sure as I have a jspec N/A which had no coolers intill I put them there :tongue:
