Alpine headunit removal
im trying to get the alpine headunit that came with the car out , I cant find any alpine removal keys anywhere !! not even on the net ( seems to be every make but alpine ) so anyone know how to get the dam thing out ?
leave the door open while you go shopping for 30 mins, the Chavs will soon have it out :D
Just call in your local ICE shop sure they'll do it for a drink.
went to halfrauds and they gave me some european remover key and dont fooookin fit or work. should have guessed really !!
Take it round paul's, He'll be able to sort it for you!
If not bring it to mine, I'll get my oxyacetylene and welding mask out! :D
also i remmeber someone not to far from has the same headunit you have karl and has just removed it so i could help you as well,
...it's easy. remove the fascia - it's only 4 screws - then you can remove the framework that the head unit is in - another 4 screws. Plus you'll have access to all of the wires etc.
Good luck
Jack
Take the whole dash apart! It might be that the headunit is bolted in from the back and you'll need to unbolt it by getting to the back of it. That's what I had to do when taking a friends headunit out.
A-ha! I found a universal headunit removal tool............
HTH bud. Always here to help - you know that.
Remove the face, in the centre on the left and right are 2 small round "pins", lift them up or down into the centre (as needed), and pull the unit out.
Baz
