NZR Computer Boffins.
I am trying to install a cardbus adaptor for my laptop but the intall wizard keeps coming up with "Could not install hardware, an error occured during installation of the device a service installation section in this INF is invalid" What can I do?? Cheers in advance.
  • Replies 30
  • Views 513
It is usually on the cd from the manufacturer. This error usually happens when you try to install a PCMCIA card before you havce intalled the adaptor.
The adaptor??
The PCMCIA adaptor in the laptop. Ther slot that the card fits into needs to be installed also, hence the INF file error...
You should have the software on the CD from the manuf...
I assume you have the latest service packs installed???
Uninstalled it all and started again from scratch started again with Installation file 0xserINF and it came up with "the device was installed correctly but could not be started [Error 0x0000045E]. As for updates they are all installed as far as I am aware.
Can you give some details? Laptop make and model, hardware make and model, drivers etc?
Toshiba Satelite Pro A10, ST LAB RS 232 Cardbus Adaptor PCMCIA RS232. As for information on Drivers I do'nt know?? I am running Windows XP.
Is there any entry in the system and application event logs???
Sorry mate but how do I find the application event logs, as this has never happened before I do'nt know how to find the relevant info. :o
start, run the type eventvwr. You should have 3 logs, system, application and security.
Go to system and start at the top and see if any are showing red. Copy the details here...do the same for app log...
To find teh event logs - Right click My Computer & left click manage.
Under that should be Event Viewer - open that and click on Application Logs.
Angus in probably right - if you've never used the PCMCIA cards before its probably a driver related issue.
j
cheek...of course I am right...lololol
type source category event
Error CFT NONE 1
Error CFT NONE 2
Error Cdrom NONE 7
I have loads of the above as well as some yellow warning symbols saying:
Warning plugplaymanager 256
the results from the log should look like this....
This has come up in the bottom box cdrom Error:
0000: 03 00 68 00 01 00 b8 00 ..h...¸.
0008: 00 00 00 00 07 00 04 c0 .......À
0010: 00 01 00 00 00 00 00 00 ........
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 f8 6d 10 00 00 00 00 .øm.....
0028: a0 ae 05 00 00 00 00 00 *®......
0030: ff ff ff ff 03 00 00 00 ÿÿÿÿ....
0038: 40 00 00 c4 02 00 00 00 @..Ä....
0040: 00 20 0a 12 48 02 00 40 . ..H..@
0048: 00 00 00 00 0a 00 00 00 ........
0050: 00 00 00 00 a8 bf 19 81 ....¨¿.
0058: 00 00 00 00 70 0e b0 ff ....p.°ÿ
0060: 02 00 00 00 bf 0d 02 00 ....¿...
0068: 28 00 00 02 0d bf 00 00 (....¿..
0070: 10 00 00 00 00 00 00 00 ........
0078: 70 00 03 00 00 00 00 0a p.......
0080: 00 00 00 00 02 00 00 00 ........
0088: 00 00 00 00 00 00 00 00 ........
And this in the cft error:
0000: 00 00 00 00 01 00 50 00 ......P.
0008: 00 00 00 00 01 00 07 21 .......!
0010: 01 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
the real info is in the top box,,,under description....
And in app errors Application Hang:
0000: 42 75 63 6b 65 74 3a 20 Bucket:
0008: 31 32 36 38 31 38 32 36 12681826
0010: 39 0d 0a 9..
And MsiInstaller :
0010: 39 0d 0a 9..
Event Source: PlugPlayManager
Event ID: 256
Description: Timed out sending notification of device interface change to window of
This event ID is a warning message that you can safely ignore. The warning basically means that an application registered to receive Plug and Play (PnP) device interface notifications but didn't respond to a notification within 30 seconds.
*****x, sorry :o
Here you go: fault bucket 126818269
and: The Device \Device/Cdrom0, has a bad block.
This is what the online help says:
Details
Product: Windows Operating System
Event ID: 7
Source: Cdrom
Version: 5.2
Symbolic Name: IO_ERR_BAD_BLOCK
Message: The device, %1, has a bad block.
Explanation
The device has a bad block of memory, which Windows attempted to read. The data might be missing or corrupted.
User Action
Do one or all of the following:
Retry the operation.
Clean the physical hard drive.
Use newer media.
Version: 5.0
Component: System Event Log
Explanation
User Action
Use newer media.
And this:
Details
Event ID: 1001
Source: Application Hang
Version: 5.2
Symbolic Name: DW_BUCKET_LOG
Message: Fault bucket %1.
Explanation
The indicated program stopped responding. The message contains details on which program and module stopped responding. A matching event with Event ID 1001 might also appear in the event log. This matching event displays information about the specific error that occurred.
User Action
No user action is required.
